Forums >> Revit Building >> Technical Support >> ghost callouts
Tue, Oct 10, 2006 at 9:22:57 PM | ghost callouts
rgaaia
is there a way to get a "ghost callout" to indicate the location of a enlarged detail elswhere with out actually "calling it out to a new detail??? I just simply want to echo the location of the same detail at different locations on a section. thanks for any help on this!!!
Wed, Oct 11, 2006 at 7:09:17 AM | RE: ghost callouts
laurabh
After you select "Callout" in the design bar, check the box next to "Reference other view." Select the desired view from the list and then make the callout bubble. You can modify the tag to have SIM, TYP, OPP, etc. by editing the tag.
Wed, Oct 11, 2006 at 7:20:33 AM | RE: ghost callouts
rgaaia
thanks so much!!!!!
How to delete Ghost Windows in the Model?
Mon, Apr 28, 2014 at 2:56:19 PM
Are Callouts Vew Specific?
Wed, May 12, 2010 at 3:56:06 PM
Windows below only show when Ghost Surfaces is turned on?
Thu, Feb 2, 2012 at 4:44:00 PM
HELP! callouts are not visible!!
Sat, Feb 16, 2008 at 12:17:21 PM
Callouts and Callout Sim Views
Thu, Sep 12, 2013 at 10:41:57 AM
Page generation time: 0.5570
