20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Is it crop region or something else? Splitting up a drawing correctly matchline
I have a house that I just added a large patio and now it falls off the sheet. So instead of moving everything to a larger sheet, I thought it would be easy to simply do a match line and show it on a different sheet. So I did a copy of the first floor plan and renamed it to be called patio. Then I used the crop region to only show what I want to show of the patio. The problem is I can see text and room names outside of my window. So when I put it onto the new sheet, it's has all this extra stuff.
How do I split up a drawing correctly?
I think that you have split it correctly. It sound right anyway. The room tags are view specific. So, if you have room tags showing up off of the crop region you can just delete them. They show up because the center of your room space is within your crop region. Just delete them (the tags) in the view that you don't want to see them in.
Also check out this thread from a few weeks ago.
Revitcity Forum Index >> Technical Issues >> Plan views on a sheet with matchline
ArchWestCY
Step matchline with crop region? |
Wed, Sep 5, 2007 at 5:05:22 PM
callouts and crop regions |
Thu, Oct 29, 2009 at 8:31:28 AM
Crop Region not cropping all info |
Thu, Jul 27, 2006 at 10:33:17 AM
Annotation lines outside the crop region |
Thu, Jun 16, 2016 at 8:55:13 AM
Separating drawing into two sheets crop view problem |
Thu, Apr 14, 2011 at 3:57:35 PM
