Forums >> Revit Building >> Technical Support >> Room schedules
Tue, Oct 10, 2006 at 2:10:51 PM | Room schedules
iREV
3.5 Stars: 3 Votes
Is there any way to show only the total counts and names without listing the instances in a schedule?
Tue, Oct 10, 2006 at 2:50:11 PM | RE: Room schedules
TomDorner
4.5 Stars: 25 Votes
Try unchecking the "itemize every instance" box on the schedule sorting and grouping tab. Tom
Wed, Oct 11, 2006 at 12:42:01 PM | RE: Room schedules
iREV
3.5 Stars: 3 Votes
That didnt work. Apparently you must show at least one feild in order to have a schedule
Wed, Oct 18, 2006 at 10:12:38 PM | RE: Room schedules
trich00
Just a suggestion - Have you tried to create a calculate value field and then use the "hidden field" for the other fiels you don't want to see.
Fri, Oct 20, 2006 at 11:54:39 AM | RE: Room schedules
iREV
3.5 Stars: 3 Votes
Yes I am currently doing just that. If there is a formula that will make it so that I do not see all the rooms at once I would like to know this. The schedule shows all the rooms. I would like to show just the Room Type and total not the instances.
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
Room schedules
Thu, Feb 7, 2013 at 4:44:14 PM
Large number of schedules
Mon, Jun 20, 2011 at 12:56:18 PM
Room Numbers in Schedules
Wed, Jan 25, 2006 at 3:26:56 PM
Family Schedules going room-by-room
Wed, Jan 22, 2020 at 12:52:54 PM
Page generation time: 0.7197
