Forums >> Revit Building >> Technical Support >> Missing Level symobl on Sections
Tue, Oct 10, 2006 at 12:27:32 PM | Missing Level symobl on Sections
MYoung
MYoung Avatar
Hey everyone, I set up a large underground parkade with levels P1 and P2, and when I take a section, some of the level graphics don't show up (ie P1 45'-0" with a centerline at that level). None of the visibility settings seem to be a factor, as everything is turned on, and some of the other level graphics such as L1 do show up. I could manually put in the level symbol, but I know it should automatically come up with the section. Any ideas? Thanks
Tue, Oct 10, 2006 at 1:07:27 PM | RE: Missing Level symobl on Sections
jmessner
Make sure that the end/start points of the levels you are missing are extended through/past the point that your section is cut. you can verify by looking at the elevations
Tue, Oct 10, 2006 at 1:20:07 PM | RE: Missing Level symobl on Sections
archdan
3.5 Stars: 2 Votes
Also check to make sure that your crop region includes where the levels are located vertically.
Tue, Oct 10, 2006 at 1:30:56 PM | RE: Missing Level symobl on Sections
MYoung
MYoung Avatar
Awesome, yeah that worked. Thank you very much!
sections and level lines
Wed, Jul 12, 2006 at 4:39:50 PM
LEVEL Annotation Missing
Mon, Dec 11, 2006 at 3:41:47 PM
Sections, different level/views
Sat, Aug 5, 2017 at 7:34:44 AM
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
Mystery of the deleted level tag.
Wed, Aug 20, 2008 at 3:20:54 PM
Page generation time: 0.3997
