Forums >> Revit Building >> Technical Support >> A Sloped Curve Wall
Tue, Oct 10, 2006 at 8:13:21 AM | A Sloped Curve Wall
m10allen
I have viewed several postings on sloping walls and I have tryed them also and have found that I must be doing something wrong. Can anyone provide me with a step-by-step way to create a sloped top, curved wall? Or point me in the direction to find this help. Thanks.
Tue, Oct 10, 2006 at 9:09:40 AM | RE: A Sloped Curve Wall
stevelj
Just use a ref plane. Set the angle you want and use attach top to make it so.
Tue, Oct 10, 2006 at 9:31:16 AM | RE: A Sloped Curve Wall
m10allen
Thanks, Steve!!! It worked perfectly!!!
Thu, Aug 7, 2008 at 2:17:30 PM | A Sloped Curve Wall
AbelGoddard
AbelGoddard Avatar
May have worked perfectly for HIM, but see attached for what MINE looks like. NOT perfect.  :-(
Helping you Be Able to be the person you want to be!
Sign up for my free newsletter, Being Able, at http://www.AbelGoddard.com
Thu, Aug 7, 2008 at 2:51:48 PM | A Sloped Curve Wall
4 Stars: 205 Votes
ABEL, i don't forgot this question, but right now i'm in the middle of a render, when "HE" finish i take a look of this, OK?
I think it could better use REFERENCE LINES and nor REF. PLANES but will see....
Edited on: Thu, Aug 7, 2008 at 3:11:12 PM
Thu, Aug 7, 2008 at 3:52:25 PM | A Sloped Curve Wall
Abel ... you found out what happens when you take the advice that was given.  You want the top of the wall flat across the normal (pirpendicular) and the previous advice will not do that.  In 2009, you could create your wall as an inplace blended sweep.
Thu, Aug 7, 2008 at 4:16:53 PM | A Sloped Curve Wall
4 Stars: 205 Votes
Hi abel, you dont need REF PLANE or REFERENCE LINE, WWHUb was right, a "Void Sweep"solve the problem...
Thu, Aug 7, 2008 at 4:17:27 PM | A Sloped Curve Wall
coreed
coreed Avatar
4 Stars: 16 Votes
i like the inplace blended sweep suggestion also.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
curve sloped massing wall problem (plz HELP!!!)
Wed, May 9, 2007 at 5:15:43 AM
HELP! Curved Sloped wall with slanted top
Sat, Jul 26, 2008 at 9:16:29 PM
12
EDITING CURVE WALL
Thu, Mar 8, 2012 at 1:21:14 PM
Curve Walls
Mon, Dec 22, 2008 at 6:13:27 PM
Door in sloped wall, need help building frame
Mon, Jun 23, 2014 at 2:25:11 PM
Page generation time: 2.0662
