19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Granite countertops
I am trying to make granite countertops. I tried a solid extrusion, but it doesn't accept assigned materials. How can I do this and put in a sink hole?
29 Posts No Rating |
You can put in the sink hole by either using a void extrusion or by editing the solid extrusion to extrude around the sink. As for the material question i have the same problems when creating the family outside of a project.
creating a "floor" for your countertops work well.... you can set the height of the countertop "floor" 3ft above your level, (set your thickness). You can asign a material type to it and use the "opening" fearture under the modeling tab to create the openings for sinks.
Thanks for the help.
Does anyone has a granite texture?? |
Tue, Apr 11, 2006 at 11:31:15 AM
Invisible Countertops |
Fri, Mar 14, 2008 at 10:43:14 AM
Countertops |
Wed, Sep 21, 2005 at 5:58:20 PM
Scheduling Countertops |
Tue, Sep 20, 2005 at 9:33:35 AM
Scheduling Mass Objects (countertops) |
Tue, Sep 20, 2005 at 9:17:48 AM
