Forums >> Revit Building >> Technical Support >> Copying objects from model to model
Fri, Oct 6, 2006 at 4:48:04 PM | Copying objects from model to model
bigstein
Hi I am dealing with linked models - i am trying to copy a stair from one model to the other, but I am running into problems - the paste aligned options are grayed out and not available. is there no way to do this? BS
Fri, Oct 6, 2006 at 5:11:47 PM | RE: Copying objects from model to model
bigstein
nevermind.
Sun, Oct 8, 2006 at 3:13:12 PM | RE: Copying objects from model to model
zine
I am trying to copy windows from one model to another but having issues doing this. I need the sill hight to remain the same, but nothing seems to line up? Any ideas? Thanks Ian
Mon, Oct 9, 2006 at 2:41:53 AM | RE: Copying objects from model to model
nandini
you cannot have the parameters all the same...they change...but the placment will be the same. sil height however has to be reset.
Copying elements from a linked architectural model into my host structural model
Thu, Feb 12, 2015 at 4:30:35 AM
linked model shows over objects
Mon, Aug 8, 2011 at 2:47:39 PM
Copying elements from a linked architectural file...
Thu, Sep 25, 2008 at 9:01:59 AM
HELP - Copying groups around ... causes mass objects inside to copy elsewhere?!
Sat, Jan 20, 2007 at 4:58:06 AM
Link in Arch Model's walls instead of copying them into Structural
Tue, Jun 16, 2015 at 1:23:00 PM
Page generation time: 1.3535
