Forums >> Revit Building >> Technical Support >> Model Groups
Fri, Oct 6, 2006 at 3:01:25 PM | Model Groups
goathead
I need to create a standard 1st floor and then use the same floor on multiple floors above in the same building. I've had a suggestion to use Model Groups to do this, but have never worked in model groups before. Any suggestions?
Fri, Oct 13, 2006 at 7:31:56 PM | RE: Model Groups
iREV
3.5 Stars: 3 Votes
I am currently doing this. Use tall walls through out your building and then group the rooms that are the same. Then go to edit copy to clipboard and then paste aligned in edit and select the floors you want these floors to be on.
Why can't I use model groups in a legend and how do I get around it?
Thu, Feb 24, 2011 at 5:40:54 PM
Transfering model groups
Tue, Apr 30, 2013 at 1:40:02 PM
Tags for model groups?
Wed, Jan 27, 2010 at 10:13:36 AM
Attached detail groups missing from model groups...
Mon, Aug 17, 2009 at 8:11:10 AM
Model Pattern in Mirrored Groups
Fri, Apr 17, 2009 at 5:23:13 AM
Page generation time: 1.4214
