Forums >> Revit Building >> Technical Support >> Stone Walls, Stone Veneer, etc
Thu, Oct 5, 2006 at 5:30:48 PM | Stone Walls, Stone Veneer, etc
MongooseST7
MongooseST7 Avatar
How does one construct a stone wall in Revit ? How does one construct a stone veneer over frame construction to the 3 foot level with stone sill and conventional siding the rest of the way to top of wall ( stone to waterline)?
Fri, Oct 6, 2006 at 6:56:09 AM | RE:
daudesign2
Basically you build two walls, one on top of the other to the required elevation, and assign the specific walls whatever material. The stone sill is an extrusion set to whatever elevation and assigned a material.
Fri, Oct 6, 2006 at 7:00:02 AM | RE: Stone Walls, Stone Veneer, etc
jfurlong
i would concider this to be a very basic function so my advice is to look up the revit help or tutorials that come with revit. look up Verticall compound wall.
Fri, Oct 6, 2006 at 8:21:58 AM | RE: Stone Walls, Stone Veneer, etc
rkitect
rkitect Avatar
4 Stars: 29 Votes
Second that. Stacked Walls (Vertical Compound) are the way to go on this one.
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Stone Veneer and Framing Plan
Wed, Nov 14, 2007 at 12:12:22 PM
Inserting stone into brick veneer
Mon, Nov 13, 2006 at 9:58:31 PM
whats the best way to show stone veneer on your rendering
Fri, Mar 5, 2004 at 9:03:10 PM
Stone walls
Sat, Jan 12, 2013 at 5:40:42 AM
Page generation time: 3.5402
