25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Spot Elevations
I am trying to place spot elevations along various section of a stepped foundation. I seem to be able to only place the sport elevation on the top of the lower foundation wall. All the rest I cannot highlight the foundation wall, only the attached footing below the wall. Tried all kinds of tab tricks, hiding things, changing the view cut planes, and so on. Anybody got any ideas how I can add spot elevations to the top of a stepped foundation?
Thanks in advance.
OK I found a solution. The cut plane of the view must be above the top of the wall that I want to select. Then I hid all of the extraneous stuff like other walls, then placed the spot elevations, then changed the cut line back.
Is there an easier way?
Setting a manual height for Spot Elevations in plan |
Wed, May 27, 2015 at 8:03:11 AM
Spot elevations |
Fri, Jul 29, 2016 at 8:01:28 AM
Revit Spot Elevations, Rooms and Color Schemes Problem |
Mon, Jun 24, 2013 at 12:46:35 PM
Revit refusing to use Spot Elevations |
Mon, Oct 14, 2013 at 3:47:54 PM
13
Spot elevations off by 1/4" ? |
Wed, Aug 11, 2010 at 4:41:55 PM
