Forums >> Revit Building >> Technical Support >> OLE Insertion
Wed, Oct 4, 2006 at 10:51:25 AM | OLE Insertion
Geer
I have tried to insert into a AutoCAD dwg file the Link into Revit 9 or Revit Structure 3 I am using AutoCAD 2007to cerate the dwg file. I keep getting a proxygraphics error. I have attached the error message I get. What am I doing wrong?
Wed, Oct 4, 2006 at 6:49:47 PM | RE: OLE Insertion
eldados
eldados Avatar
4.5 Stars: 8 Votes
have you tried typing "proxygraphics" in Autocad? if not, do so and set the value to 1 just type 1 and enter... HTH
Integrator
KarelCAD
Thu, Oct 5, 2006 at 7:52:33 AM | RE: OLE Insertion
Geer
Yes I tried to set the proxygraphics to 1 and 0 and I still get the same error message
Revit Export Block Insertion Points
Fri, Oct 2, 2009 at 2:16:39 AM
linking ole objects in Revit project
Mon, Jul 25, 2005 at 8:47:41 AM
Export insertion point???
Thu, May 4, 2006 at 2:31:08 AM
Insertion Point of Custom Titleblocks / Title Blocks
Tue, Oct 13, 2009 at 2:57:30 PM
insertion points
Mon, Jan 19, 2004 at 1:43:12 PM
Page generation time: 0.0218
