9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> "Line in Sketch is slightly off axis and may cause inaccuracies."
33 Posts No Rating |
When I made a detailed duplicate of my Site Plan for a Landscape Plan, I got this message: "Line in Sketch is slightly off axis and may cause inaccuracies."
And it's right! There are at least a couple lines off. Does anyone know why this happens?
Thanks in advance,
Poppy
32 Posts No Rating |
I have a related problem, the error msg has the element id of the skecth line that is offending, but I cannot select when in the review warnings function, or by use the select by id tool in the sketch mode for the floor. How can I find the offending sketch line. The floor is complex and redrawing it is a big hassel and may not fix this problem anyway.
Thanks to anyone with a solution!
Well I solved it myself. Turns out you can select by ID if you are in the shetch mode for the object that has the sketch line in it!
Revit is usally as smart as I think it should be!
Lines slightly off axis |
Thu, Nov 9, 2006 at 1:36:13 PM
walls slightly off axis? |
Thu, Jan 15, 2009 at 5:06:36 PM
SLIGHTLY CROOKED |
Wed, Jul 16, 2008 at 10:26:35 AM
RESOLVING WARNING MESSAGES |
Wed, Oct 28, 2009 at 11:25:06 AM
Axis in elevation is funky |
Wed, Mar 25, 2009 at 1:07:48 PM
