15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Shadow export
Is there a way to export a shodow study (advanced model graphics->cast shadows) from revit into autocad. I was hoping to have the shadow turn into a hatch pattern, can't seem to make it work. Exporting it as an image doesn't help.
Sorry Steve, I'm seeing nothing that will do this
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
create a new type of filled region called shadow
in ithe filled regions properties change its surface pattern to solid fill and give it a colour say magenta
trace over your shadow
export to dwg
you should now have a hatch where your shadow was.
that puts the "work" in "work-around"! I decided to import the autocad site plan into revit and let revit cast the shadows.
Shadow Casting |
Thu, Feb 12, 2009 at 10:00:48 PM
Doors make a gray shadow in Sections |
Wed, Apr 7, 2004 at 10:39:43 AM
Drawing won't export with shadows on |
Fri, May 10, 2013 at 12:18:38 PM
Need to show shadow of canopy on ground |
Mon, Dec 26, 2016 at 12:30:35 AM
Shadow is not visible when rendering |
Wed, Mar 19, 2008 at 11:23:54 AM
