Forums >> Revit Building >> Technical Support >> UNDERLAY FREEZING
Tue, Oct 3, 2006 at 12:48:17 PM | UNDERLAY FREEZING
CuriousAboutRevit
1 Stars: 1 Votes
Hey all....was wondering if you can freeze your underlay, so that when you are sketching walls overtop you do not accidentally move the walls (or furniture) that is beneath (as the underlay) Hope that made sense....really cramming for an answer..THanks guys!
Tue, Oct 3, 2006 at 1:37:48 PM | RE: UNDERLAY FREEZING
mcoffey
You can sort of freeze it. Go to the level you have as your underlay and select all of the objects you don't want to change and pin them. Then when you switch to the other level you won't be able to move any of those pinned objects.
Tue, Oct 3, 2006 at 2:09:05 PM | RE: UNDERLAY FREEZING
CuriousAboutRevit
1 Stars: 1 Votes
That's great...it worked well...I am wondering now...can you unpin everything quickly...I noticed when I went to unpin my level...I had to manually unpin each and every single object on that level...YUCK!
Tue, Oct 3, 2006 at 2:23:17 PM | RE: UNDERLAY FREEZING
mcoffey
Yes, you can unpin them all at once. Select everything you've pinned. Then on the Edit drop down pick Unpin Position. That will unpin everything. You can also just select everything and type UP for Unpin Position and PP for Pin Position. Post edited on 2006-10-03 14:25:33
Tue, Oct 3, 2006 at 3:50:16 PM | RE: UNDERLAY FREEZING
CuriousAboutRevit
1 Stars: 1 Votes
Thanks A LOT! Very appreciative...See You Posting Soon...
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
Underlay is not working
Mon, Apr 28, 2014 at 5:29:50 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
misguided underlay
Tue, Feb 19, 2013 at 8:14:29 AM
wrong underlay showing
Mon, Jan 27, 2014 at 1:29:57 PM
Page generation time: 1.0774
