12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Interior and Exterior Doors
11 Posts No Rating |
I need to export Revit files to AutoCAD DWG's to match specific client standards. Does anyone know of any way to specify between interior and exterior doors in Revit. So, when I export to AutoCAD they will be on different layers.
Thank you,
Matt Coffey
You can try creating a subcategory (either interior or exterior or both) under doors. Then under File >> Import/Export Settings, you can set up how the doors will export to DWG.
HTH.
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
I tried that. It still will only export the doors to the same layer. I think I'd need to create a family for interior and exterior doors and somehow specify in the family if they are interior or exterior. I just haven't figured out how to do that yet. Thanks for your suggestion though.
Take a look at this family (assuming you are using Revit 9). I added some subcategories to to the family (while in family editor, Settings >> Object Styles), then selected the Panel extrusion of the door and placed it in the subcategory 'Interior - Panel' for instance. You do this for each element you need to be on a different layer. Then setup your Export settings like mentioned above. You'll probably have to make a seperate door family for exterior and a seperate family for interior to get this to work correctly.
Let me know if you have any other questions about it.
Thanks for your help. I'll give it a look.
Exterior windows and doors |
Thu, Feb 7, 2013 at 7:18:53 AM
DWG Export Interior/Exterior on others than walls? |
Wed, Nov 17, 2010 at 1:57:26 AM
Looking for Large 3, 4 & 5 Panel Exterior Glass Sliding Doors. (Florida Style) |
Fri, Feb 16, 2007 at 12:39:11 PM
Glass & Window Trouble while Rendering interior view? |
Tue, Jun 19, 2007 at 4:15:21 PM
Interior/Exterior Lighting |
Fri, Oct 8, 2010 at 12:53:05 PM
