Forums >> Revit Building >> Technical Support >> rendering images not being replaced
Mon, Oct 2, 2006 at 5:14:57 PM | rendering images not being replaced
belyo
i render a view, capture image, it askes me if i want to replace it (yes), updates my presentation sheet... save, relinguish, close. open the next day and all the renderings except one revert back to the old renderings... any help is appreciated, thanks, Brian
Mon, Oct 2, 2006 at 8:08:26 PM | RE: rendering images not being replaced
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I remember this issue back from Revit 4.5 It struggles with the replacing of the image. Rename the old file first or delete it before capture the other rendering. For this reason and also file size. I always export out the images rather than keeping them in the file and then re-import them as required if they need to go on sheets. HTH.
Regards,
Chris.
Rendering images from the internet
Mon, Jun 20, 2011 at 12:20:16 AM
Basic Rendering Question: Are .bmp & .tiff images usuable for materials?
Thu, Oct 26, 2006 at 5:25:40 PM
Issues with Importing Images into Revit - Help needed please
Mon, Jul 10, 2006 at 9:31:35 AM
Document Will Not Render
Fri, Aug 27, 2010 at 3:57:28 PM
Rendering Images for vertical metal wall panels and standing seam roof?
Wed, Apr 19, 2006 at 9:13:39 AM
Page generation time: 0.8849
