Forums >> Revit Building >> Technical Support >> Mullion Array gone Arry
Mon, Oct 2, 2006 at 2:45:50 PM | Mullion Array gone Arry
rkitect
rkitect Avatar
4 Stars: 29 Votes
I've been piddling with this problem all day. If someone could take a look at this family and let me know what is going on, that would be greatly appreciated. Essentially when I change the height of the window, the mullion unlocks itself from the sill height plane and steps down. This only happens when 'No. of Mullions' is >2. Thanks for any help you can give. -Carl
Mon, Oct 2, 2006 at 3:02:49 PM | RE: Mullion Array gone Arry
jron
I just redid the dimension lines. Set the sill height first, then set the o/a height. then reset the parameters
Mon, Oct 2, 2006 at 3:15:11 PM | RE: Mullion Array gone Arry
rkitect
rkitect Avatar
4 Stars: 29 Votes
For as nice of a program Revit is.. sometimes it has some of the strangest quirks... Thanks jron.
Wed, Oct 4, 2006 at 4:21:30 PM | RE: Mullion Array gone Arry
rkitect
rkitect Avatar
4 Stars: 29 Votes
Correction, Reseting the Height and Default Sill Height parameters only fixed the problem within family editor. For some reason when this 'fixed' family gets put back into the project, it begins misbehaving again (and I did over ride existing parameters). Any other suggestions would be greatly appreciated. TIA,
Wed, Oct 4, 2006 at 5:28:35 PM | RE: Mullion Array gone Arry
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Read my tutorial... Smile on my blog Edit the nest mullion family. Goto an elevation Select the bottom reference plane that overlays the reference level. Go to its properties Note that its set to "Not a reference" Change it to reference bottom and name it bottom. Save and reload into the project. Unconstrain the elevational settings of the mullion and then reconstrain them. HTH.
Regards,
Chris.
Thu, Oct 5, 2006 at 9:17:10 AM | RE: Mullion Array gone Arry
rkitect
rkitect Avatar
4 Stars: 29 Votes
Thanks Chris, I thought it would noteworthy to mention that while chaging the ref. plane to 'Bottom' didn't not fix the problem by itself, I did notice that the last/second element in the array was not locking properly to the plane I wanted it to lock to. Reseting that lock did fix teh problem. Thanks for everyone's help!
Is Solution to Creating a Parametric Polar Array?
Tue, Oct 22, 2013 at 8:40:06 PM
How to nest a mullion array family into a window sash
Mon, Nov 28, 2016 at 12:30:49 PM
array
Mon, Feb 26, 2007 at 3:09:19 PM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
Page generation time: 0.9563
