Forums >> Revit Building >> Technical Support >> Aligning views
Fri, Sep 29, 2006 at 1:07:47 PM | Aligning views
GeneralissimoDigital
Not sure where this post belongs, but - How do I set up multiple sheets with floor plan views so they are all aligned at the same location on each sheet? Ditto with the drawing title bullet when I move it.
Fri, Sep 29, 2006 at 2:33:20 PM | RE: Aligning views
laurabh
It isn't possible to align different views on different sheets. And if I understand your second question correctly, it isn't possible to have the view title at the precisely same location between different views. You can, however, align view titles with other view titles on the same sheet. As you move the title, if you're getting close to aligining (either horizontally or vertically) with another title, a reference plane will appear that you can snap to.
Fri, Sep 29, 2006 at 3:08:33 PM | RE: Aligning views
tha't surprising - but thanks
Tue, Mar 11, 2008 at 8:54:46 PM | Aligning views
Oak3s
Any update with this for 2008?
Thu, Mar 20, 2008 at 6:27:30 AM | Aligning views
JFK64
Basically I "CHEAT" with the good old fashion way. Draw a line at some referenced point in the drawing (i.e. grid intersection) Copy it to the other sheet pages and then do the closest point to the view to that common referenced point. Not the greatest method but better than nothing
John K
Aligning of views!
Wed, Sep 5, 2007 at 6:59:36 AM
Problem aligning views on sheets
Tue, Aug 12, 2008 at 9:48:23 AM
View Titles not aligning within sheet
Sun, Nov 2, 2014 at 11:45:17 PM
Aligning Annotations & Views
Tue, Mar 31, 2009 at 5:23:15 AM
Aligning Grout Lines in Render Materials
Fri, Dec 16, 2011 at 6:47:21 AM
Page generation time: 1.5253
