Forums >> Revit Building >> Technical Support >> Make Crop Regions Print
Fri, Sep 29, 2006 at 10:07:30 AM | Make Crop Regions Print
SteveB
3.5 Stars: 5 Votes
What is the setting to make the crop regions print. under view properties, they are set to "visible" already but they don't print.
Fri, Sep 29, 2006 at 10:17:09 AM | RE: Make Crop Regions Print
bolandereric
When you go to print click on Setup and down at the bottom their is a ckeck box that says hide crop boundaries uncheck it and the crop boundaries will print. Post edited on 2006-09-29 10:17:54
Crop Regions can't crop imported images
Mon, May 5, 2008 at 2:25:13 AM
Changing Lineweight of Crop Regions
Mon, Jun 19, 2017 at 8:39:07 AM
dimension text un-movable when crop regions applied to a wall section?
Wed, Feb 14, 2007 at 8:40:59 AM
Crop Regions, Keynotes & Room Tags
Sun, Dec 31, 2006 at 7:12:23 PM
Irregular Crop regions (Revit 2008)
Mon, Jan 28, 2008 at 12:00:04 PM
Page generation time: 4.0984
