Forums >> Revit Building >> Technical Support >> Sweep Lineweights
Fri, Sep 29, 2006 at 10:07:10 AM | Sweep Lineweights
erin
5 Stars: 2 Votes
I have a couple families (door and windows) with fairly complicated trim, which I built as a sweep. I want all the lines of the trim to show on the interior elevations, but they seem to be defaulting to medium lines, and I really need them to be thin lines so there isn't just a big black blob. Is there any way to control this, apart from going through a coupld dozen views with the linework tool? Thanks. -Erin
Fri, Sep 29, 2006 at 2:40:28 PM | RE: Sweep Lineweights
laurabh
It can be controlled through Visibility/Graphics if the trim sweeps are in their own subcategory.
Fri, Sep 29, 2006 at 3:02:14 PM | RE: Sweep Lineweights
erin
5 Stars: 2 Votes
They aren't a seperate subcategory, they're jsut sweeps within the door or window family. How would I make them a seperate subcategory? I know how to choose a subcategory, but I can't figure out how to make a new one. I haven't gotten very far into making families; I mostly just modify others to meet my needs. Thanks. --Erin
Fri, Sep 29, 2006 at 3:15:10 PM | RE: Sweep Lineweights
laurabh
I've taken the same route with families - modifying existing ones to what I need. It's fairly easy to create a new subcategory. 1. In the family editor, go to "Settings -> Object Styles." Check to see if there is already one called "Trim". If so, skip to step 3, if not, go to step 2. 2. In the dialog box, click on "New" under "Modify Subcategories." Enter a name for the subcategory and make sure it's a subcategory of windows or doors (whichever you're editing at the time.) After you press Okay, you can modify the default settings for lineweights. 3. Now right click on the trim piece. In the Element Properties dialog, under "Identity Data" There will be a subcategory parameter. Select Trim from the drop down list. 4. Then just reload the family into your project. You'll have to do this for each separate family. Once it's loaded into your project, if you decide that you want it to appear differently in different views, just use the Visibility/Graphics overrides as you would with any other object. Good Luck!
Fri, Sep 29, 2006 at 3:33:09 PM | RE: Sweep Lineweights
erin
5 Stars: 2 Votes
That's it! Thanks so much. I was really dreading spending the rest of the day with the linework tool...
Fri, Sep 29, 2006 at 3:37:12 PM | RE: Sweep Lineweights
laurabh
No problem. That's what these kind of forums are for.
Lineweights Issue
Thu, Nov 17, 2005 at 6:05:35 PM
Lineweights Question
Wed, Aug 3, 2005 at 4:03:11 PM
Revit lineweights
Wed, Jan 28, 2015 at 9:31:49 AM
Revit Lineweights not printing correctly
Fri, Jun 14, 2013 at 1:27:49 PM
revit 2008_ lineweights in 3d views vary.
Tue, Apr 22, 2008 at 8:49:57 AM
Page generation time: 3.1490
