Forums >> Revit Building >> Technical Support >> Window tags not showing
Thu, Sep 28, 2006 at 12:37:25 PM | Window tags not showing
malfonsi
4.5 Stars: 2 Votes
I am having difficulties in having my transom window tags showing on my floor plans. I understand that generally that Revit will not show the tags outside of the view rang. Is there a way to work around this? Is there a trick to get this to work the way I want it to?
Thu, Sep 28, 2006 at 12:50:46 PM | RE: Window tags not showing
TomDorner
4.5 Stars: 25 Votes
Try temporarily moving the cut plane up o cut through the transom windows, then tag them and move cut plane back to normal. The tags should stick. You of course could also use a "plan region" and adjust the cut plane just for that area which should allow tagging as well. HTH Tom
Thu, Sep 28, 2006 at 1:10:48 PM | RE: Window tags not showing
malfonsi
4.5 Stars: 2 Votes
It did not work. My view range settings were Top: 7'-6" and Cut Plane: 4'-0" My transom's sill height is 8'-0" and head height is 9'-6" Therefore: I changed the Top: 9'-0" and CUt Plane: 9'-0" I then tagged them. When I change the cut plane to 4'-0", they show up. However the overlapping transoms to the windows below cancel each other out. (The widows don't show). So when I change the Top back to 7'-6" the tags dissapear. I then edited my Transom Window and ajusted my visibilty to not show in plan. When I reloaded this, it now works. Thanks for your help. It really did help. I just wanted to share my conclusion and solution with everyone.
Window tags & showing window #(Mark) on plan
Thu, Nov 3, 2005 at 9:46:11 AM
Window tags disappear when I copy the window...
Fri, Jun 14, 2013 at 2:19:23 PM
Window Tags not working
Fri, Sep 24, 2010 at 7:30:45 PM
window tags in elevation
Tue, Feb 13, 2007 at 12:51:56 PM
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:05 PM
Page generation time: 2.4931
