11 Users Online (9 Members):
Forums >> Revit Systems >> Technical Support >> Revit Systems duct connections
How do I tap a round duct to the underside of a rectangle duct using the Autodesk Revit Systems software
8 Posts No Rating |
See the Mechanical Tutorial, Completing the Supply Air Systems, Placing AC Units. This is a tap off the side, not the bottom, but you should be able to follow those steps (p. 10 in an elevation view and get it done. Simply select Round Duct with the Diameter that you want, start the duct at the centerline snap of the rectangular duct, and extend to the circular duct you're connecting to. Jay
8 Posts No Rating |
See above, that's page 108.
4 Posts No Rating |
Try using the section view to make the connection. Also you could get better results if you have the tap connection type set to standard.
Duct Systems. |
Mon, Aug 5, 2013 at 7:48:16 AM
Revit MEP 2010 Duct System Colors |
Tue, May 18, 2010 at 6:04:49 PM
Rectangular Flex Duct |
Tue, Jan 21, 2014 at 2:45:16 PM
Multiple Connections One Family |
Sun, Nov 7, 2010 at 7:58:51 PM
Duct System problem |
Fri, Jan 11, 2013 at 8:05:19 AM
