Forums >> Revit Building >> Technical Support >> Complex Linetypes in Revit?
Wed, Sep 27, 2006 at 9:33:48 PM | Complex Linetypes in Revit?
patriot
Is there any way to create or import complex linetypes as used by civil engineers and surveyors in autocad into Revit? To keep documentation looking the same, I need to be able to create linetypes which are not standard dash and dot format -----O------- _______//////_______ Some linetypes also need to have text in them. Is this possible in Revit?
Thu, Sep 28, 2006 at 7:09:52 AM | RE: Complex Linetypes in Revit?
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this it may help http://revitbeginners.blogspot.com/2006/09/utility-lines-workaround.html HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jul 2, 2012 at 9:46:49 AM | Complex Linetypes in Revit?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Have there been any updates since 2006 in Revit's capability to handle more complex linetypes? Surely there must be a way to draw gas lines, storm lines, etc. with text or symbols in the line. Is the answer just creating a repeated detail by itself? If so, I don't understand why the workaround posted above requires a line and THEN a repeating detail...why not just a repeating detail with the line built in?
Mon, Jul 2, 2012 at 10:13:22 AM | Complex Linetypes in Revit?
Check out the family here
http://www.revitcity.com/forums.php?action=viewthread&thread_id=2927
Mon, Jul 2, 2012 at 10:49:57 AM | Complex Linetypes in Revit?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Ok, thanks for the lead.
That still doesn't seem better than just a repeating detail with the letters or symbols just drawn in. Is this the best way to do it? How do your offices do existing electric lines, high temperature water lines, etc.?
Mon, Jul 2, 2012 at 11:34:47 AM | Complex Linetypes in Revit?
Thread Post Kudo! #6
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Try this family I have.  It is line based so all of the text will automatically fall into place as you draw what you need.
http://www.revitcity.com/downloads.php?action=view&object_id=12871
Mon, Jul 2, 2012 at 1:51:38 PM | Complex Linetypes in Revit?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Looks like it works well...when I get Revit 2013 I can try it out!
DWG Revit export replacing linetypes with erronous linetypes
Tue, Mar 17, 2015 at 10:07:42 AM
Getting CAD Linetypes into REVIT
Thu, Jul 24, 2008 at 7:11:10 PM
Complex Revit Drawings
Wed, Feb 2, 2011 at 5:55:23 PM
Linetypes and Phases
Thu, Dec 1, 2005 at 5:29:34 PM
Custom Linetypes
Wed, Nov 7, 2007 at 5:53:17 PM
Page generation time: 3.8643
