Forums >> Revit Building >> Technical Support >> Level Symbols on Elevations
Tue, Sep 26, 2006 at 4:42:18 PM | Level Symbols on Elevations
strandcad
In some of my elevation views, the level tags that I want on there do not show even though the level is created. Any suggestions?
Tue, Sep 26, 2006 at 6:04:34 PM | RE: Level Symbols on Elevations
DTS
There could be a variety of reasons. Try on the view properties under parameter EXTENTS untick "far clip offset" If that doesn't work on the elevations that have the levels you want visible, select them and on the tool bars above click on propagate extents, tick the boxes you want the elevations to show. It only works if for example the elevations are opposite one another i.e. north south or east west. It works on sections too. YOu could draw a temporary section line, if it cuts through a level line, select the levels you want and click on propogate extents as well. Check HTH
Wed, Jan 10, 2007 at 8:10:35 PM | Level Symbols on Elevations
Westview
2.5 Stars: 2 Votes
Try hovering over the level line that does not show, right click and pick show anotationin view.
Tue, Sep 15, 2009 at 8:26:20 AM | Level Symbols on Elevations
JayDee08
In the Elevation view, hit View Properties from the right click menu, and uncheck both Crop View and Crop Region Visible, the missing elevations datums should appear, somewhere maybe far away from the scene... if they haven't been deleted.
Hiding Level Bubbles to internal elevations
Tue, Dec 10, 2013 at 4:10:45 PM
Level elevations
Thu, Sep 11, 2014 at 12:54:39 PM
Section Symbols Disappear
Wed, Feb 9, 2011 at 1:13:50 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Deleting import symbols
Thu, May 8, 2008 at 3:14:21 PM
Page generation time: 2.4077
