Forums >> Revit Building >> Technical Support >> Can't draw walls slightly off orthographic (straight)
Mon, Sep 25, 2006 at 8:35:14 PM | Can't draw walls slightly off orthographic (straight)
JebG
This is a really annoying problem, but is probably easily solved? I am trying to draw walls with a survey underlay, the existing building is not straight and when I draw the walls or lines the program stops me from drawing lines that are slightly diagonal. I do not have the grid on, I have turned off the length & angular snaps, and all other snaps apart from intersection, end line etc. To get the line to follow the survey I have to draw the line then rotate it afterwards, really silly way of drawing. Can anyone help
regards JebG
Mon, Sep 25, 2006 at 9:11:43 PM | RE: Can't draw walls slightly off orthographic (straight)
Poppy1977
If the underlay is a JPEG or other Raster image, you've got me. This is an annoying stumble. However, if you've imported a vector image, you sould be able to select "Pick Line" after you've selected "Detail Lines" or "Lines". Poppy
How do I Draw a Wall Slightly (low angle) of Axis
Mon, May 13, 2013 at 3:16:45 PM
Orthographic Dimensions
Tue, Mar 11, 2008 at 6:29:02 PM
Should I draw house at angle?
Tue, Aug 3, 2010 at 9:49:32 PM
Slightly Curved Stair
Mon, Dec 3, 2012 at 3:47:35 PM
Lines slightly off axis
Thu, Nov 9, 2006 at 1:36:13 PM
Page generation time: 0.6727
