Forums >> Revit Building >> Technical Support >> Possible Corruption in 9.1
Mon, Sep 25, 2006 at 7:25:05 PM | Possible Corruption in 9.1
psymon
psymon Avatar
3.5 Stars: 6 Votes
This message has been posted on the Augi forum, (see below) unfortunately this is a locked forum and I cannot not post. Has anyone else come accross this problem? Does anyone have a reccomendation for what to do if we have converted to 9.1 and are currently working with worksets on such a project. Losing 4 months of work would quite possibly suck a lot. Wes Macaulay Revit Bldg Wishlist Mgr Join Date: May 2003 Location: Vancouver, BC CANADA Posts: 2,355 Possible corruption issue in 9.1 -------------------------------------------------------------------------------- Workset-enabled projects created prior to Revit 9, upgraded to Revit 9, and then upgraded to 9.1 may experience corruption. The issue will be addressed in a new build of 9.1 that will come out soon. In the meantime, wait to upgrade projects that fall under this category until the new build arrives. __________________ Wes Macaulay LEED AP Vancouver, BC CANADA (604) 676-6000 ext.114 www.pat.ca The Leaders in Revit Building and Revit Structure "Using anything but Revit would be totally, utterly and in all other ways INCONCEIVABLE
Tue, Sep 26, 2006 at 9:42:02 PM | RE: Possible Corruption in 9.1
psymon
psymon Avatar
3.5 Stars: 6 Votes
I can't believe that there are no comment on this important topic. Does no-one use worksets and 9.1 out there and are concerned about losing their projects?
Wed, Sep 27, 2006 at 9:30:57 AM | RE: Possible Corruption in 9.1
JHanby
3.5 Stars: 3 Votes
Sorry, we only recieved our 9.1 disks last week and are still using 8.1. So far I am the only one in my office using the program so the bosses aren't in too much of a hurry to upgrade.
Jill
Wed, Sep 27, 2006 at 10:30:05 AM | RE: Possible Corruption in 9.1
gdoorn
1 Stars: 1 Votes
we started a few projects on 8.1 and are now running 9.1. i havent experienced any problems.
Wed, Sep 27, 2006 at 10:32:09 AM | RE: Possible Corruption in 9.1
corymac82
We are using 9, and haven't received 9.1, yet. I guess I shouldn't be in a hurry to upgrade. -cory
Wed, Sep 27, 2006 at 11:52:40 AM | RE: Possible Corruption in 9.1
kesflower
3.5 Stars: 11 Votes
We still haven't even received 9.1. But from the looks of this post and others out there, it'll be better for us to just wait for the next send out of 9.1 anyway.
Ruth Rau
Main Street Architecture, P.C.
Wed, Sep 27, 2006 at 1:26:44 PM | RE: Possible Corruption in 9.1
trich00
We worked started in 9.0 with worksets and upgraded to 9.1 - We have had no problems so far. just a suggestion - upgrade your central file first then do a save as to your personal file. Trying to upgrade your personal file and then saving to central casued problems when we upgraded from 8.0 to 8.1
Wed, Sep 27, 2006 at 2:16:21 PM | RE: Possible Corruption in 9.1
iREV
3.5 Stars: 3 Votes
I had the same problem with our workset. Revit 9 and 9.1 cannot share worksets it must be upgraded. So make sure everybody is using Revit 9.1 that is working on that workset. You must first detach the central file in 9 and then upgrade the workset in revit 9.1 and then save a new central file and create new worksets for each person. Not hard to do and there is no fallout from doing this.
Wed, Sep 27, 2006 at 4:16:09 PM | RE: Possible Corruption in 9.1
akccrox
Until every local file is forced to turn into its own central file or else you can't save and that is what we experienced with both upgrades.
Wed, Sep 27, 2006 at 4:19:50 PM | RE: Possible Corruption in 9.1
akccrox
If you experience the problem i mentioned you fix it by saving a local as the central file thereby upgrading the file to 9.1. You can not upgrade the existing central file directly and in fact have to delete it. Post edited on 2006-09-27 16:20:20
Thu, Sep 28, 2006 at 12:23:30 AM | RE: Possible Corruption in 9.1
#11
puzzle
4 Stars: 10 Votes
The problem that we found with 9.1 was that you could not save over a network. Our office lost 3 jobs. It has been a bit slack of Autodesk not to send out a e-mail or letter. Something to let us know there may be a problem. Don't get me wrong, I love using Revit.
Macca
Sunshine Coast
QLD Australia
Thu, Sep 28, 2006 at 12:32:13 AM | RE: Possible Corruption in 9.1
#12
psymon
psymon Avatar
3.5 Stars: 6 Votes
thanks for all the replies. We have not had any problems ourselves and I was just worried that we may lose some projects. It seems that the problem is not that widesppread. We always have the local file as a backup I guess.
Thu, Sep 28, 2006 at 10:48:29 AM | RE: Possible Corruption in 9.1
#13
jfurlong
I allways give this advice to my clients as i was told this from a reliable source. always finish a project in the version of revit that you started it in. i know some projects may last a few years, but migrating a project from one release to another can cause different problems.
Corruption error message.
Thu, May 10, 2007 at 1:47:09 PM
Design Options Error
Wed, Dec 2, 2015 at 4:22:03 PM
Taging
Thu, Aug 26, 2010 at 4:53:24 PM
File corruption issues
Wed, Aug 8, 2007 at 11:53:04 AM
Corruption Warnings - Revit 2008
Fri, Jan 25, 2008 at 11:36:45 AM
Page generation time: 0.3393
