Forums >> Revit Building >> Technical Support >> import/export line weight setting - is it possible between two projects?
Sun, Sep 24, 2006 at 2:43:25 PM | import/export line weight setting - is it possible between two projects?
Molonesh
and another one - is it possible to trim several lines by another line in one command like trim does in Autocad? Thanks
Sun, Sep 24, 2006 at 5:15:44 PM | RE: import/export line weight setting - is it possible between two projects?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
On you trim command, tick multiple in the options bar. You still need to pick the lines one by one, but you'll only need to click the cut/extension line once. HTH.
Mon, Sep 25, 2006 at 1:03:13 PM | RE: import/export line weight setting - is it possible between two projects?
Molonesh
Thanks but triming that way is not what you expect from a software by autocad. It is like very basic command that should be there.
Mon, Jan 14, 2008 at 9:17:07 AM | import/export line weight setting - is it possible between two projects?
lbrooksher
tried to report that this post title is mis-leading (not so much offensive).  The subject line has nothing to do with the content
Tue, Jan 22, 2008 at 9:29:20 AM | import/export line weight setting - is it possible between two projects?
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
It appears it was two questions but no one answered the subject question.
That is my question. Is there a way to export/import line weight settings between different projects and families?
It's got to be happy hour somewhere
Tue, Jan 22, 2008 at 9:48:12 AM | import/export line weight setting - is it possible between two projects?
lbrooksher
see... http://www.revitcity.com/forums.php?action=viewthread&thread_id=9908
Tue, Jan 22, 2008 at 10:06:09 AM | import/export line weight setting - is it possible between two projects?
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
Thank you!
Import & Export Line Weights - setting them
Fri, Apr 1, 2011 at 12:45:54 PM
Import DWG Line Weight
Thu, Apr 16, 2009 at 7:49:32 AM
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
LINE WEIGHT PROBLEM IN PRESPECTIVE
Tue, Mar 13, 2012 at 3:26:45 PM
Text Line Weight
Sat, May 5, 2007 at 11:34:38 AM
Page generation time: 0.6637
