Forums >> Revit Building >> Technical Support >> Same Wall, Different Problem
Fri, Sep 22, 2006 at 6:51:33 PM | Same Wall, Different Problem
Poppy1977
When I created this wall style, I had no clue it would give me so much trouble. Now, I'm having problem getting rid of seams when windows or doors are placed in this wall. I've attached the wall and window if anyone has time to look at it. Any suggestions would be so greatly appreciated! Please, help, if you have any suggestions. I have to submit the first of the week, and I don't want to have the sketch everything in to clean it up. Thanks in advance, Poppy
Sun, Sep 24, 2006 at 6:26:34 PM | RE: Same Wall, Different Problem
DTS
TRy this solution This is host wall sweep. If you don't like the section it cuts then you can create a detail component to cover it up. At least it fixes all your seams.
Sun, Sep 24, 2006 at 8:00:48 PM | RE: Same Wall, Different Problem
Poppy1977
Thank you, thank you! Easy fix right in front of me. Sorry about the fuss on not getting a response. I think I see why, I need to come up with more challenging problems. None the less, I am grateful you (DTS) took the time to address this one! Thanks, Poppy
Wall crossing problem
Thu, Apr 11, 2013 at 5:37:44 PM
Problem with an angled curtain wall
Mon, Jun 18, 2012 at 1:39:37 PM
11
Horizontal wall
Tue, Mar 20, 2018 at 2:48:21 PM
Problem with wall connections
Thu, May 5, 2011 at 4:12:35 PM
Wall Cleanup Problem
Thu, Dec 4, 2008 at 5:39:14 AM
Page generation time: 1.0859
