Forums >> Revit Building >> Technical Support >> diameter symbol
Thu, Sep 21, 2006 at 6:41:31 PM | diameter symbol
shiuh
hi all, can anyone tell me how to do a diameter symbol on text ? thanks
Thu, Sep 21, 2006 at 8:30:30 PM | RE: diameter symbol
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Refer FAQ on my blogsite Ø diameter is created with Alt+0216 (on numpad or copy from character map)
Regards,
Chris.
Fri, Sep 22, 2006 at 1:17:48 AM | RE: diameter symbol
vijayakumar
Thanx for the informations
Vijayakumar
Wed, Oct 11, 2006 at 6:35:57 PM | RE: diameter symbol
shiuh
hi all how do i do a degree symbol then?
Wed, Oct 11, 2006 at 7:01:14 PM | RE: diameter symbol
ecarson
Try this ALT+0176 There is a heap of symbols not sure how many work with Revit though http://en.wikipedia.org/wiki/Windows_Alt_keycodes Ewan Carson Melbourne, Aus
Wed, Oct 11, 2006 at 7:13:32 PM | RE: diameter symbol
framerman
4 Stars: 13 Votes
In Windows go to Start>All Programs>Accessories>System Tools>Character Map. You can find almost ay character in there, click it and copy paste it is one way and the alt+ method is the easier way if you can remember some of the commands.
Thu, Oct 12, 2006 at 3:55:22 PM | RE: diameter symbol
shiuh
cheers...thats great help.
Fri, Jul 29, 2016 at 9:08:41 AM | diameter symbol
LLParchitect
1 Stars: 1 Votes
Try Start>All Programs>Accessories>System Tools>Character Map.
For free revit families I would check out www.specifiedby.com. Recently started using it. It's also the largest BIM library in the United Kingdom.
Outside Diameter vs. Nominal Diameter
Tue, Jul 29, 2014 at 8:30:33 PM
Revit MEP pipe diameter difference
Mon, Feb 13, 2012 at 10:32:46 AM
%%d ? what happened?
Wed, Oct 28, 2009 at 5:08:09 PM
diameter
Thu, Jun 25, 2009 at 6:29:59 AM
Elevation symbol visibility
Tue, Nov 5, 2013 at 7:36:03 AM
Page generation time: 0.5836
