Forums >> Revit Building >> Technical Support >> AutoDesk Buidling Systems - MEP
Thu, Sep 21, 2006 at 4:16:41 PM | AutoDesk Buidling Systems - MEP
bigstein
Hello Is is possible to bring in work created by MEP engineering consultants who work in ABS as a mass and run interference checks? Thanks BS
Thu, Sep 21, 2006 at 4:28:54 PM | RE: AutoDesk Buidling Systems - MEP
TomDorner
4.5 Stars: 25 Votes
From the Autodesk website: 7. What about object compatibility between Autodesk Revit Building and Autodesk Architectural Desktop and Autodesk Building Systems? Revit Building can read and write ACIS® solids. This capability gives users a way to export their models from Autodesk® Architectural Desktop and Autodesk® Building Sys­tems software and import or link 3D information into Revit Building. Use this method to cut sections and per­form visual interference detection.
Revit MEP Buidling with repetition
Thu, Oct 18, 2012 at 4:42:26 AM
How to improve the coordination between precast construction and MEP systems?
Fri, Oct 31, 2025 at 3:46:56 AM
Dealing with plumbing systems
Fri, Aug 31, 2012 at 5:27:33 PM
MEP crossover to ABS from AutoCAD
Sun, Aug 20, 2006 at 5:32:36 PM
Specific piping systems in Revit MEP
Wed, Sep 30, 2009 at 6:37:29 PM
Page generation time: 3.6987
