Forums >> Revit Building >> Technical Support >> Trouble w/ grids
Thu, Sep 21, 2006 at 2:55:23 PM | Trouble w/ grids
bigstein
Hello All I am working in my model and realized that one of my grid lines has been deleted from one of my plan views. Not sure how this happened. When I try to copy and paste in the grid line from another view, it automatically re-numbers the bubble to the next highest number in order. What am I missing here? Please advise, Thanks BS
Thu, Sep 21, 2006 at 3:21:33 PM | RE: Trouble w/ grids
ArchWestCY
4.5 Stars: 7 Votes
I would like to hear others input on this subject. I had the same problem a couple of days ago. I went to a view where the grid line was still present and right-clicked on it. Then I clicked Maximize 3D Extents. It kind of messed up the length of the line, but it did show back up in all views. Then, I had to go back and place the ends of that line would match the others. It's a little bit of work, but it did solve the problem. Does anyone have a better idea? ArchWestCY
Thu, Sep 21, 2006 at 3:22:56 PM | RE: Trouble w/ grids
TomDorner
4.5 Stars: 25 Votes
Grids cannot be copied from other views as they are a universal component in the revit model. What most likely happened is that it did not get "deleted" but rather you lost the visability of the grid. The first thing to check is that the grid intersects your plan view. Go to an elevation and make sure it goes up in 3D to intersect your plan. You can also check your other views and make sure that yur grid is set to 3D and maximize its 3D extents. Also check to make sure you did not "hide annotation in view" If you hover over where the grid should be in the view and you see a grid line highlite, then right click and select "show annotation in view" HTH Tom
Thu, Sep 21, 2006 at 4:15:02 PM | RE: Trouble w/ grids
bigstein
I clicked show annotation in view and it worked! Thanks! BS
Thu, Sep 21, 2006 at 5:13:54 PM | RE: Trouble w/ grids
ArchWestCY
4.5 Stars: 7 Votes
Cool, that's a lot easier than what I had to do. My grids did not show up when I hovered. I did look for them that way. ArchWestCY
Thu, Sep 21, 2006 at 8:33:39 PM | RE: Trouble w/ grids
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I Suggest having a good read up on datums in the help menu. Once you understand exactly how they operate and display they are really quite simple and straight forward.
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids
Tue, Sep 1, 2015 at 8:35:46 AM
adjusting grids using temporary dimensions
Thu, Nov 22, 2012 at 12:05:29 AM
DIMENSIONing GRIDS - on plan view
Thu, May 26, 2011 at 1:33:19 PM
Page generation time: 0.3226
