Forums >> Revit Building >> Technical Support >> Canted wall?
Thu, Sep 21, 2006 at 10:52:24 AM | Canted wall?
twannen
twannen Avatar
I'm new to Revit and this may be an easy answer... But I want to put in a canted wall. Shouldn't I be able to rotate it in elevation or something?
Thu, Sep 21, 2006 at 11:28:26 AM | RE: Canted wall?
corymac82
I've had the same trouble with canted walls. I don't know the best way to do it, but there's one option that I've used before. Try creating a roof as your wall. Obvioiusly the software won't recognize it as a wall, but it should work for you as a quick fix.
Thu, Sep 21, 2006 at 2:08:32 PM | RE: Canted wall?
TomDorner
4.5 Stars: 25 Votes
You can creat a canted wall a couple of ways: 1. Do an in-place family by going to the Modeling Tab>Create then choose Walls. Use a sweep or solid extrusion. 2. Create a mass with a sloped face and then do a "Wall by Face" command found on the Massing menu. You may want to check out the Revit help file for more info. Tom
How do i make a Canted Wall?
Sat, Sep 1, 2012 at 1:47:24 AM
Canted walls
Mon, Jan 19, 2004 at 2:02:17 PM
How do you make a canted or leaning curtainwall?
Wed, Jul 21, 2010 at 8:07:26 PM
Editing end of canted wall condition
Sun, Nov 4, 2012 at 2:47:30 PM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:07 PM
Page generation time: 1.5725
