Forums >> Revit Building >> Technical Support >> Changing line weight of callout bubbles?
Thu, Sep 21, 2006 at 10:39:04 AM | Changing line weight of callout bubbles?
bigstein
Hello - Is there a way to change the line weight (thickness) of callout bubble? Thanks BS
Thu, Sep 21, 2006 at 11:07:49 AM | RE: Changing line weight of callout bubbles?
ArchWestCY
4.5 Stars: 7 Votes
Go to the Settings Tab, and down to the Object Styles. This box looks just like the Visibility dialog. Callouts are going to be under the Annotations Tab. You can adjust the lineweight here, as well as the linetype. This is the same place that you would give your walls more pop. Revit defaults to some skinny wall lines. ArchWestCY
Thu, Sep 21, 2006 at 11:33:59 AM | RE: Changing line weight of callout bubbles?
bigstein
Thanks How long have you been using Revit? BS
Thu, Sep 21, 2006 at 2:38:28 PM | RE: Changing line weight of callout bubbles?
ArchWestCY
4.5 Stars: 7 Votes
I've been using Revit since version 8, but I have been throughn into an Cadd Manager job. I am responable for making sure everyone else in my company is able to run Revit. I'm the problem solver, and Revit City is my biggest help. I couldn't do my job effectively if not for the help of all my friends at Revit City. Thanks to everyone ArchWestCY
callout bubbles and dashed lines
Thu, Apr 12, 2007 at 5:02:46 PM
changing property line weight in Revit 2009
Thu, Jun 18, 2009 at 12:58:52 PM
Changing line weights to hatching?
Wed, Apr 26, 2006 at 10:44:00 PM
Changing line patterns and weight below the ground line
Mon, Apr 29, 2013 at 7:24:23 AM
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
Page generation time: 0.4674
