Forums >> Revit Building >> Technical Support >> Can't Create Sweep
Wed, Sep 20, 2006 at 12:55:18 PM | Can't Create Sweep
goldichick
Ok, this might be a stupid quiestion, or have no answer.... Im trying to edit a family and in the process i need to edit a sweep. When i do what i need to do and try to finish the sweep the error box pops up telling me that REVIT cannot create the sweep. Is there any way to figure out exactly why it wont? What are some reasons this might be happening? Ive checked any other objects that might be in contact with the sweep that might influence it, but i cant seem to figure out what is preventing the program from creating it. This has happened to me with a few different families now so i know its not just this one.
Wed, Sep 20, 2006 at 2:39:47 PM | RE: Can't Create Sweep
hisdirt
5 Stars: 5 Votes
Hi goldichick, Yeah this is a pretty common error message with sweeps, it tends to mean that something is too small. It could be that it turns a corner too tight (can be an easy fix by moving the path to the inside of the problem corner), or it could be that a line in the profile is too small (top of my head the shortest line length is 0.53mm or something). Hope this helps!
Can't create sweep
Tue, Jul 31, 2012 at 11:02:14 AM
Sweep problem
Wed, May 21, 2014 at 9:21:16 AM
Sweep Question
Tue, Mar 7, 2006 at 3:01:15 PM
Having problems when trying to create a Steeple using Sweep
Wed, Apr 28, 2010 at 2:29:19 PM
11
Parametric sweep profile?
Mon, Jul 17, 2006 at 8:32:12 AM
Page generation time: 1.2928
