Forums >> Revit Building >> Technical Support >> Material Display Issues in Walkthrough
Tue, Sep 19, 2006 at 4:33:58 PM | Material Display Issues in Walkthrough
hgrigel
4 Stars: 1 Votes
I have created a walkthrough that essentially travels around the exterior of my building model. The walkthrough is in the Site file that has the building file linked. The exterior walls have a stone veneer that should appear as a light brown or tan, but for some reason in the walkthrough they appear as black. All of my other materials show up fine. Most of my materials are custom materials I have created, but I don't think this is the issue because only one of the materials is not showing up correctly. I would think they would all have a problem if it was because I created the materials. Also, the stone veneer appears correctly in every other view, just not the walkthrough view. Any help would be greatly appreciated! Thank you!
walkthrough issues
Tue, Apr 12, 2011 at 5:20:36 AM
Walkthrough in realistic view, not rendered
Wed, Aug 27, 2014 at 12:00:38 PM
Walkthrough compression issues
Fri, Jan 16, 2009 at 10:44:43 AM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
walkthrough questions
Sun, May 10, 2009 at 7:49:41 PM
Page generation time: 3.1695
