Forums >> Revit Building >> Technical Support >> Flexable Arch Family
Mon, Sep 18, 2006 at 9:18:38 AM | Flexable Arch Family
jstewart
A person in my office created a Niche with an arch and he did a great job everything works great except for the trim. The spring point and the trim refuse to work together. I tried and tried to get it to work but at some point you just have to scream for help! So "HELP" can anyone figure out what we are doing wrong or is it an impossible task? Thanks Post edited on 2006-09-18 09:19:11
Mon, Sep 18, 2006 at 9:23:23 AM | RE: Flexable Arch Family
Chymos
tagging along
Mon, Sep 18, 2006 at 5:34:50 PM | RE: Flexable Arch Family
eldados
eldados Avatar
4.5 Stars: 8 Votes
can't download it to check, can you please email it to me? thanks
Integrator
KarelCAD
Mon, Sep 18, 2006 at 7:51:59 PM | RE: Flexable Arch Family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I can't break it here? How is working correctly? Give me an example of the parameters you are using to break it and what is incorrect.
Regards,
Chris.
Tue, Sep 19, 2006 at 6:36:16 AM | RE: Flexable Arch Family
Chymos
I am the one in jstewart's office that created the family. The problem is with the trim around the arch. We want the family to be flexible in width, height, and want the spring point of the arch to be flexible. Everything works great but the trim. The "inside" edge of the trim works fine because it is attached to the opening cut. The outside edge of trim at the "corner" where the trim changes from vertical to begin the arch is where the problem lies. Simple geometry tells us that if the radius of the arch changes, the relationship between the inside corner and the putside corner of the trim will no longer be the same. For example, when the arch has a smaller radius and gets flatter, the outside edge of the trim at the corner will be slightly higher than it would be if it were a true arch. Revit wants us to tell it exactly where this point should be, but the only information we can provide to Revit is a distance from the inside edge of trim. I guess we are asking Revit to calculate where the outside corner should be and Revit does not want to do that! :-) I have tried to attach the family file again to this message. Please let me know if it does not come through this time. Thank you for your efforts!
Tue, Sep 19, 2006 at 9:49:04 AM | RE: Flexable Arch Family
jstewart
"What he Said" Smile
Tue, Sep 19, 2006 at 10:53:14 AM | RE: Flexable Arch Family
dduarte
dduarte Avatar
3 Stars: 2 Votes
Your arches just needed to be re drawn with the "Arc from center and endpoints" line tool. Looks like you were trying to constrain the top of your arch. That was causing the centerpoint of your arch to shift up and down. Post edited on 2006-09-19 11:04:51
David
Tue, Sep 19, 2006 at 5:56:38 PM | RE: Flexable Arch Family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes although i don't think i'd redraw using the different arc sketch tool as that doesn't really make a difference. Just edit the sketch of the trim, select the arcs and go to their properties and turn on the centre mark and constrain that. There is no need to constrain the end points as they are joined to the other edges of the trim which are already defined. HTH.
Regards,
Chris.
Tue, Sep 19, 2006 at 6:04:47 PM | RE: Flexable Arch Family
dduarte
dduarte Avatar
3 Stars: 2 Votes
Constraining the centerpoint of the arcs was the first thing I tried but I was getting over constrained errors so I just redrew the arcs. Post edited on 2006-09-19 18:05:41
David
Tue, Sep 19, 2006 at 7:09:46 PM | RE: Flexable Arch Family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Cool.
Regards,
Chris.
Thu, Sep 21, 2006 at 6:50:07 AM | RE: Flexable Arch Family
#11
Chymos
Dduarte, yes, we tried that as well and I took a look at the revised family you made. The problem with it now is that the top of the arch does not stay the same when you change the spring point. Changing the spring point should leave the top of the arch in the same place, but raise the "corners", thus making the arch flatter (with a larger radius). I really think that this function may be impossible, but wanted to see if anyone else has been successful in creating such a family.
Thu, Sep 21, 2006 at 2:04:45 PM | RE: Flexable Arch Family
#12
mott45
I think I may have fixed your issue. Easiest way to get what you are trying to accomplish is to use a sweep for the trim. That way you only really have 1 line to worry about controlling. Hope this helps. BTW, good call on dimensioning the arcs. I find that most of the people that I help/train don't even know you can do that! Winking
Thu, Sep 21, 2006 at 2:15:11 PM | RE: Flexable Arch Family
#13
jstewart
PERFECT! mott45 Looks like that solved it. Thank you so much!
Thu, Sep 21, 2006 at 3:10:20 PM | RE: Flexable Arch Family
#14
Chymos
First off, mott45, welcome to the RevitCity Family (no pun intended). Secondly, yes, that appeared to do the trick. We thought about doing a sweep, but figured the trim dimensions could not be flexible if we did so. So much for preconceived notions! We should have tried that MUCH earlier. Thanks a mil for everyone's help!
Brick Arch Family - Do you have one??
Tue, Apr 12, 2016 at 10:35:54 AM
Brick arch family coming in at 90degree to correct alignment
Tue, Mar 12, 2013 at 7:41:21 AM
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Fri, Jan 14, 2011 at 1:27:26 PM
When I import REV. ARCH Link, it lands way outside my work space
Fri, Oct 9, 2009 at 12:22:40 PM
Page generation time: 2.4068
