Forums >> Revit Building >> Tips & Tricks >> how to add new aq. render materials
Sat, Sep 16, 2006 at 10:32:34 PM | how to add new aq. render materials
harenmangukia
is that jpeg files or it is scaned files?
Tue, Oct 3, 2006 at 9:10:21 AM | RE: how to add new aq. render materials
rkitect
rkitect Avatar
4 Stars: 29 Votes
well, seeing as scanned files can be jpg files.. the answer is yes. Some of them are photos of actual materials. Many of them also have transparency maps and such attached to them. So if you scan an image of a material in, yes, you can use it as a material. is this what you are asking?
Tue, Oct 3, 2006 at 9:31:34 AM | RE: how to add new aq. render materials
ArchWestCY
4.5 Stars: 7 Votes
Using maps is fairly easy, but how do I make a new material library. Is that a .mlib file. I have AutoCAD 2007 and it comes with hundreds of materials. Is there a way to make a revit material library with these materials in it, or should I just continue to apply them as maps? ArchWestCY
Fri, Oct 13, 2006 at 8:34:36 AM | RE: how to add new aq. render materials
framerman
4 Stars: 13 Votes
It appears manual unfortunately. I'd like to do the same. Under setting>materials click the arrow beside AccuRender then click the material menu and click new. Or you can use the user library when you make new materials to store in. I don't know of any batch program that will do this manually.
Render materials lost link
Mon, Nov 30, 2009 at 9:36:59 AM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Materials not showing in render
Wed, Jul 6, 2011 at 1:14:38 PM
Adding new render material
Wed, Nov 2, 2011 at 10:39:45 PM
Can't get any materials to render
Tue, Jun 2, 2009 at 9:49:29 AM
Page generation time: 0.8961
