11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> titleblocks
when i create a new titleblock there are
three choices for line weights- thin, medium,
and wide.. however i want a much wider line
on my titleblock.. how can i do this?
28 Posts No Rating |
Change the thickness of the wide line in the"line styles" setting, and create there new line styles as much as you need. I have created a line style for every pen weight - so i know what to use at drafting to get a certain weight.
This can be done quite easily. The confusing thing is in families linestyles are not controlled in the linestyle settings, they are controlled in the object styles. So if you create a new objectstyle in your object style settings and set the appropriate linetype and weight then new linestyles will be available for use of the same name.
I wouldn't suggest changing the wide lines in the family, as typically this object style is already set in projects and when you load it into a project the amended lineweight will not be updated, so you'd have to update your template file with thi.
HTH.
TitleBlocks |
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options |
Mon, Dec 8, 2008 at 2:06:33 PM
Labels in Titleblocks? |
Mon, Nov 10, 2008 at 3:30:01 PM
Titleblocks |
Mon, Mar 17, 2008 at 3:03:10 PM
Multiline text on Titleblocks |
Sun, Oct 5, 2008 at 8:17:13 PM
