Forums >> Revit Building >> Technical Support >> wood framed walls
Fri, Sep 15, 2006 at 11:55:47 AM | wood framed walls
noyalcg
Does any one know if there are wood framed walls in revit or do you have to make them yourself, and if so how do you do it. I just started using the program a few days ago so I am not that up to speed with things. Help is appreciated.
Fri, Sep 15, 2006 at 2:25:34 PM | RE: wood framed walls
MPBgavin
I am new to revit also and work in the post frame industry. I am looking for a wall system that has a steel cover, wood wall girts, and wood columns. If you recieve any information to help you it would be appreciated if you could pass it along.
Sat, Sep 16, 2006 at 1:35:20 AM | RE: wood framed walls
vector23
vector23 Avatar
2 Stars: 16 Votes
you create a 2D overlay for the framing members.. just go to DGCAD.com and the free video tells you all about it..
Sat, Sep 16, 2006 at 5:04:06 PM | RE: wood framed walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I suggest you go through the inbuilt tutorials in revit on setting up wall types. If you're wanting to actually show the framing of the wall then one option would be to use curtain walls with the panel set to empy system panel or to use the structural framing tools... Ideally you wouldn't model them for any larger project. HTH.
Regards,
Chris.
REVIT Structure and Architecture for wood framed buildings
Thu, Apr 18, 2019 at 2:38:02 PM
recommended way of modeling wood-framed roof?
Mon, Nov 5, 2012 at 3:34:01 PM
Wood Siding
Fri, Nov 22, 2019 at 3:17:58 PM
11
Wood Framing Walls Extension Review
Thu, Sep 23, 2010 at 2:51:06 PM
Wood Framing Walls Extension; Locating and External framing
Fri, Jul 31, 2015 at 8:03:14 PM
Page generation time: 0.3105
