Forums >> Revit Building >> Technical Support >> Sill and head height of windows - in the dimension I can only show the actual
Fri, Sep 15, 2006 at 6:29:33 AM | Sill and head height of windows - in the dimension I can only show the actual
Molonesh
height of the window - is it possible to create a tag or something that will show the sill and the head height near the window? thanks
Fri, Sep 15, 2006 at 9:05:17 AM | RE: Sill and head height of windows - in the dimension I can only show the actual
Molonesh
ooppss, found it - created annotation family for windows and doors with lables for sill and head heights - works fine. Ill upload it
Sun, Aug 18, 2024 at 1:01:15 AM | Sill and head height of windows - in the dimension I can only show the actual
Samsky
Hi Molonesh, would you be able to share this tag?
Thanks.
Sam
Actual Window Head height
Thu, Jun 7, 2007 at 5:44:29 PM
Windows Default Sill Height
Fri, Aug 26, 2011 at 12:51:41 PM
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
Thu, Nov 3, 2005 at 5:19:14 PM
Default Constraints in window family
Fri, May 4, 2012 at 7:13:48 PM
Page generation time: 1.1555
