Forums >> Community >> The Studio >> A toposurface problem?
Fri, Sep 15, 2006 at 2:59:56 AM | A toposurface problem?
radhikase
Hi, When creating a toposurface by importing a Autocad drawing, if the countours in the dwg file are relative to the sea-level like 97.5 meters, etc, the toposurface created by revit has a huge mass of earth below the surface. how do i reduce the depth of this mass without redoing the dwg in autocad. till now i have resized the crop region to get the desired depth.
Fri, Sep 15, 2006 at 3:29:45 PM | RE: A toposurface problem?
bradmac
3 Stars: 1 Votes
check your levels too see if they are referencing a level well below your topo surface
Sun, Sep 17, 2006 at 3:30:30 AM | RE: A toposurface problem?
radhikase
No, the levels do not reference any other levels.
Mon, Sep 18, 2006 at 6:01:18 AM | RE: A toposurface problem?
sjs
sjs Avatar
3.5 Stars: 10 Votes
Settings -> Site Settings -> Elevation of poche base
Mon, Sep 18, 2006 at 9:16:10 AM | RE: A toposurface problem?
radhikase
Hi, Solved the Problem- In the AutoCAD drawing I had drawn the property extents - and this polyline had an elevation of 0.0!! So revit created a toposurface with one contuor as 0.0 and all others at their specified elevations. So the huge mass of earth below the toposurface. Humans err, the software doesn't!! Thanks.
toposurface problem!!!
Fri, Nov 5, 2010 at 7:40:03 AM
Toposurface problem
Thu, Feb 25, 2010 at 4:37:33 PM
Toposurface
Tue, May 11, 2010 at 9:04:45 AM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Page generation time: 1.1195
