Forums >> Revit Building >> Technical Support >> Revision sequence
Fri, Sep 15, 2006 at 1:53:14 AM | Revision sequence
Nicolas
1 Stars: 1 Votes
Is there any way in changing the revision numbering sequence from numeric (1,2,3 ect) to alphabet (A, B, C, ect)! Our job has gone to Tender and I want to start a new sequence of alphabet letter Can someone help!! Nic
Fri, Sep 15, 2006 at 3:11:13 AM | RE: Revision sequence
Will9000
4 Stars: 5 Votes
I'd also find this useful, rather tahn manually changing the section box and adding the letters, as on large projects it can get quite confusing
Tue, Sep 19, 2006 at 12:37:41 AM | RE: Revision sequence
Erik
It is a regular question with a regular answer: NO :-) It is one of those things many users spend a lot of time trying to find the solution, beacuse reason say there MUST be a setting somewhere, but no
Customizing Revision Sequence Numbering
Wed, Aug 5, 2009 at 9:51:48 AM
Revision schedule showing revision sequence numbers with empty descriptions
Thu, Feb 28, 2013 at 3:46:03 PM
Revision Schedule not updating
Tue, Aug 28, 2012 at 7:59:18 AM
Revisions in the Titleblock
Wed, Dec 2, 2015 at 2:18:27 PM
Revisions giving "Revision Number XXX is used more than once" error
Wed, Mar 8, 2023 at 12:46:18 PM
Page generation time: 0.0662
