Forums >> Revit Building >> Technical Support >> Dimensions & Crop Regions
Thu, Sep 14, 2006 at 8:44:10 PM | Dimensions & Crop Regions
Moose
1 Stars: 4 Votes
We have just updated to Revit 9.1 and have discovered that when dimensioning elevations and sections with dimension witness line control set to Fixed to Dimension Line, the witness line is connected to the edge of the crop region when dragged outside the region. Does anyone know of a toggle/setting for this? Previous versions did not have this problem and we are finding it frustrating! Thanks
Fri, Sep 15, 2006 at 12:29:44 AM | RE: Dimensions & Crop Regions
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I identified this during the beta, and am amazed to see it isn't fixed in the final release. Send the file to support so they understand the problem is wide spread and the quicker it will be fixed. HTH.
Mon, Sep 18, 2006 at 9:56:41 PM | RE: Dimensions & Crop Regions
palmer
Maybe the Fix will include my request for a toggle/setting that will alow another way to end a dimension string.
Crop Regions, Keynotes & Room Tags
Sun, Dec 31, 2006 at 7:12:23 PM
Crop Regions can't crop imported images
Mon, May 5, 2008 at 2:25:13 AM
dimension text un-movable when crop regions applied to a wall section?
Wed, Feb 14, 2007 at 8:40:59 AM
Changing Lineweight of Crop Regions
Mon, Jun 19, 2017 at 8:39:07 AM
Irregular Crop regions (Revit 2008)
Mon, Jan 28, 2008 at 12:00:04 PM
Page generation time: 1.4317
