Forums >> Revit Building >> Technical Support >> Area Boundries in created wall families
Thu, Nov 6, 2003 at 10:29:17 AM | Area Boundries in created wall families
Dr. Digital
I am making non-rectangular walls I plan and I notice that there is not a ROOM BOUNDING option in created wall families. Is there any way to have these newly created wall families behave in such a way?
Thu, Nov 6, 2003 at 12:06:43 PM | RE: Area Boundries in created wall families
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
you can use the "room separation" tool. Go to the drafting tab and choose "room separation" This is basically a line tool which you use to draw a line to separate your rooms. hope that helps! -hj-
Hiroshi Jacobs
Thu, Nov 6, 2003 at 12:21:54 PM | RE: Area Boundries in created wall families
Dr. Digital
Thanks for the reply. So this means any wall families that need to get created need to be traced by room separating lines?
Thu, Nov 6, 2003 at 12:29:33 PM | RE: Area Boundries in created wall families
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
at this point I'm pretty sure about that. -hj-
Thu, Nov 6, 2003 at 12:34:34 PM | RE: Area Boundries in created wall families
Dr. Digital
Tnak you. You have been very helpfull
Sat, Nov 8, 2003 at 7:41:37 PM | RE: Area Boundries in created wall families
FreeRangeMonkey
The correct answer to your question is that irregular walls should allow you to tag them and display area values like any other. I just created a new wall type, laid out some irregular walls with circlular, angular and rectangular orientations and then placed a room tag and it tagged fine. I turned off the room bounding box for one wall and that broke the room boundary as you would expect. I suspect there is something else going on here, but you should not have to draw room separations if you have walls enclosing your space. Maybe email the file to me and I can take a look. FRM likwid4s*nospam*@yahoo.com
Interior Elevation Crop boundries
Thu, Aug 13, 2009 at 12:13:24 PM
Two Area Plans
Thu, Feb 13, 2014 at 9:52:03 AM
Edit Topo Boundries
Wed, Jun 17, 2009 at 3:35:27 PM
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
Room Boundries - Print
Mon, Apr 24, 2006 at 3:14:15 PM
Page generation time: 0.9383
