Forums >> Community >> The Studio >> Roof Patterns
Thu, Sep 14, 2006 at 8:49:04 AM | Roof Patterns
akccrox
Does anyone know or have shingle patterns that I could download the ones in revit city don't seem to be downloadable or are corrupted somehow.
Sun, Nov 22, 2015 at 5:03:02 PM | Roof Patterns
amara58
1 Stars: 1 Votes
I HAVE THE SAME PROBLEM.  PAT FILES DOWNLOADED IN JUNE FROM RC ARE PERFECT BUT, NOW IT REFUSES TO DOWNLOAD, ONLT  APPEARS AS NOTEPAD.
Sun, Nov 22, 2015 at 6:05:46 PM | Roof Patterns
hugh
3.5 Stars: 4 Votes
We keep a list of hatch pattern sources here:
http://www.hatchkit.com.au/HatLinks.php
Hugh Adamson
www.hatchkit.com.au
Sun, Nov 22, 2015 at 7:47:10 PM | Roof Patterns
amara58
1 Stars: 1 Votes
Hi Hugh,
Thank you for the help.  Great site, easy to download.  Would you know a site where I could download the NZ conc. roof tiles as the attached pictures please.
Sun, Nov 22, 2015 at 8:04:45 PM | Roof Patterns
hugh
3.5 Stars: 4 Votes
Sorry, no.
You might find a near-enough pattern amongst the listed collections, but if you want accuracy you should consider creating a custom pattern with a hatch pattern editor.
Hugh Adamson
www.hatchkit.com.au
Wed, Nov 25, 2015 at 10:06:56 AM | Roof Patterns
marmiketin1
4.5 Stars: 10 Votes
If pat files you download are changing to just regular notepad txt files you can always make a copy of an existing pat file and rename it and then copy all the txt from notepad and put it in the pat file. also remove any of the patterns that were currently in the existing pat file.
Also if ppl do not know how to make their own hatch patterns, Revit has a pdf guide showing how it works. I have attached it.
Wed, Nov 25, 2015 at 10:09:18 AM | Roof Patterns
marmiketin1
4.5 Stars: 10 Votes
Whoops. I attached the wrong pdf in the post above. Those are a few of the ones I have made. Here is the correct pdf.
Wed, Nov 25, 2015 at 11:00:07 AM | Roof Patterns
No need to "....make a copy of an existing pat file and rename it and then copy all the txt from notepad and put it in the pat file..."   A PAT file is just a plain TXT file with a PAT extension.  Save from notepad with that extension.
Thu, Nov 26, 2015 at 12:48:41 PM | Roof Patterns
marmiketin1
4.5 Stars: 10 Votes
Have you actually tried that, you can open a .pat file in notepad to edit it but you cannot save a new .txt file you have made in notepad as a .pat
Thu, Nov 26, 2015 at 12:51:32 PM | Roof Patterns
marmiketin1
4.5 Stars: 10 Votes
nevermind. disregard my last post. i was going about it wrong. it does work if you just add .pat to the file name, i was originally trying to change the path type
ROOF HATCH PATTERNS
Fri, Jan 16, 2009 at 12:05:57 PM
Roof patterns
Wed, Apr 28, 2010 at 10:24:42 PM
Roof patterns in Metric units
Sun, Sep 9, 2007 at 7:31:43 AM
Fill Patterns disappear in Roof Plan
Thu, Jan 7, 2010 at 2:08:39 PM
on/off fill patterns
Tue, Jun 26, 2007 at 8:25:13 AM
Page generation time: 1.7827
