Forums >> Revit Building >> Technical Support >> 3D Studio
Wed, Sep 13, 2006 at 10:05:15 PM | 3D Studio
obmod
Hi, I have been able to import the dwg from Revit into 3D Studio, it doesn't bring the materials with it, how do we apply the finishes to the walls etc? I am stumped...... pls help
Sun, Oct 8, 2006 at 10:20:44 PM | RE: 3D Studio
ADSR
One of revit's nice features is that when you export 3d data in max,it's easy to identify and group the different objects(walls,railings,etc) because they are named accordingly( press "H"-select by name in max). So,if you import in max a house modelled in revit,it will be easy to select and group the walls,doors components,you name it,and asign a max material to this particular group. By default,these objects will come with the "arhitectural materials" assigned,at least with their names. The fact that 3d objects doesn't come with the revit material attached is maybe a good thing if you plan to use a 3-rd party render engine,like final render or v-ray,because they are optimised for their own material type,thus reducing rendering time a lot,really.
3D Studio Max 7 data exchange problem
Wed, Apr 20, 2005 at 2:29:13 AM
Studio Lighting
Fri, Mar 14, 2008 at 11:13:04 AM
3d Studio Max
Wed, Apr 7, 2010 at 12:25:38 PM
3d Studio Max import/link revit file
Wed, Mar 20, 2013 at 11:49:21 AM
Importing from 3D Studio Max
Fri, Jan 8, 2010 at 10:00:38 AM
Page generation time: 1.2744
