Forums >> Revit Building >> Technical Support >> Formulas and Schedules for Revit
Wed, Oct 13, 2004 at 2:15:46 PM | Formulas and Schedules for Revit
arnosandoval
5 Stars: 3 Votes
I need some help on how to use fomulas to generate costs from my Revit model. Is there a how to Tutorial out there that can walk me through the process. Thanks
Wed, Oct 13, 2004 at 3:48:55 PM | RE: Formulas and Schedules for Revit
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
in your schedule properties, under the FIELDS tab, there is a button labeled "Calculated Value" Click it and you will be able to create a new parameter that can calculate values based on other fields in your schedule... so for instance, you could calculate a total cost value by multiplying cost by count. Formulas here work the same as formulas in family parameters... the Revit Help file (F1) is a good source for information on formula syntax. Just search for "formulas" within the help file.
Hiroshi Jacobs
The Catholic University of America
Wed, Oct 13, 2004 at 5:14:29 PM | RE: Formulas and Schedules for Revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hiroshi, Just a note if you did the formula as you say you would have an inconsistent units error (i believe). You have to have the same units through the formula so you would need to remove the dollars from the cost (unless the cost in just a numeric value and not a dollar value). Regards.
Thu, Oct 14, 2004 at 8:32:27 AM | RE: Formulas and Schedules for Revit
arnosandoval
5 Stars: 3 Votes
I appreciate all your help, it seemed to work, pretty well. Thanks
Thu, Aug 30, 2007 at 11:33:21 AM | Formulas and Schedules for Revit
justinblack
Correct me if I'm wrong but you can't use the "Count" value in a formula.  It gives a long explanation but from what I can tell it's because "Count" is not a parameter of the item.
Thu, Sep 13, 2007 at 9:06:07 AM | Formulas and Schedules for Revit
arnosandoval
5 Stars: 3 Votes
You are correct.
Adding formulas to schedules
Mon, Nov 5, 2007 at 6:07:49 PM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Schedules and formulas
Tue, Jun 9, 2009 at 12:53:23 PM
Formulas for Schedules
Wed, Jul 22, 2009 at 3:31:28 PM
Panel Schedules
Thu, Jan 29, 2009 at 2:08:42 PM
Page generation time: 1.4711
