Forums >> Revit Building >> Technical Support >> Interior Elevation Tag
Tue, Sep 12, 2006 at 10:27:22 PM | Interior Elevation Tag
twebb
4 Stars: 1 Votes
I am trying to figure out how to prevent the view name from being displayed on my plans by the interior elevation tag. I have searched through view properties for the right field to uncheck, I've tried to find the tag in the Imperial Library but it does not seem to be there (i'm sure i am missing something). The previous project I worked in did not display the view names so i know it is possible, but nobody remembers how they were turned off. Any help will be much appreciated. Post edited on 2006-09-12 22:34:48
Wed, Sep 13, 2006 at 4:15:49 PM | RE: Interior Elevation Tag
twebb
4 Stars: 1 Votes
ok, i figured it out. settings-view tags-elevation tags-show view name
Wed, Jan 3, 2007 at 7:52:29 PM | Interior Elevation Tag
SGdpadilla
THANK YOU for posting this!!!  You just saved my bacon from another day of trying to figure this one out!!!
Newish Revit User :-)
Tue, Aug 28, 2007 at 8:04:45 AM | Interior Elevation Tag
grmorris
I just found that in the same menu you can change the size of the tag itself, last option at the bottom "dimension" the default is 1/2"
Someone might have figured it out somewhere else, but I hadn't seen it yet.
Mon, Aug 2, 2010 at 4:46:26 PM | Interior Elevation Tag
ohpd1
How do you do this in Revit 2011?
Mon, Aug 2, 2010 at 4:58:28 PM | Interior Elevation Tag
ohpd1
nevermind, figured it out.  it's under annotations under the families tab in the project browser.  thank you revit for keeping consistent from one version to another.
Wed, Feb 9, 2011 at 11:27:07 AM | Interior Elevation Tag
jlurie
Even after reading this, it took me a while to figure out.  So here is what I did, that so far seems to be working.  I'm using 2011.
Go to the Families area in the browser, and hit the plus to expand it.
Go to Elevation Mark Pointer_Circle.  Hover over it and right click.  Then hit edit.
The Family Editor will open.
Delete the Name, delete the reference, so that only the 1 is left.
Reload it into the project, and say yes to "overwrite existing."
Now only the number shows, not the label.
88573_elevation_tag_-_step_1.JPG88573_elevation_tag_-_step_2.JPG88573_elevation_tag_-_step_3.JPG88573_elevation_tag_-_step_5.JPG88573_elevation_tag_-_step_6.JPG
Mon, May 23, 2011 at 7:47:44 PM | Interior Elevation Tag
kathleenjennison
I can't find what you are talking about in annotations tab, could you explain further. Thank you
Mon, May 23, 2011 at 7:54:13 PM | Interior Elevation Tag
kathleenjennison
I got it, thanks
Wed, Dec 19, 2012 at 2:25:25 PM | Interior Elevation Tag
lurbas
I'm having a similar issue that's driving me crazy.  I'm trying to edit the appearance of my exterior elevation tags.  I understand how to edit families and have not had problems changing the appearance of other revit tags.  However, I can not locate the building elevation tag in order to edit it.  I've looked on multiple occasions in the Imperial Library folder as well as under the families tab in the Project Browser.  I know I must be missing something because it's just not there ??  Using 2009, but any advice would help.  Thanks!
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
Interior Elevation Tags
Mon, Jul 21, 2025 at 11:28:06 AM
Modifying Interior Elevation tag
Thu, Oct 21, 2010 at 8:32:48 AM
Adding a Tail to Interior Elevation Tag
Fri, Mar 14, 2014 at 1:10:11 PM
Changing the size of the interior elevation tag
Wed, Dec 20, 2006 at 12:26:41 PM
Page generation time: 3.8172
