Forums >> Revit Building >> Technical Support >> Reset Linework?
Tue, Sep 12, 2006 at 9:39:21 AM | Reset Linework?
ajacobs
I was wondering if there was a command or procedure to allow you to reset all of the linework you have done in a particular view. Anyone have an idea?
Tue, Sep 12, 2006 at 5:35:24 PM | RE: Reset Linework?
eldados
eldados Avatar
4.5 Stars: 8 Votes
no you can't as far as I know. you could pick a line, right click and select all instances, and than change properties.
Integrator
KarelCAD
Tue, Sep 12, 2006 at 7:45:03 PM | RE: Reset Linework?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quickest way would be to recreate the view... Alternatively you could re-use the linework tool and set it by category then pick all your linework... It will only select lines that have been overridden. HTH.
Regards,
Chris.
Can you save linework?
Tue, Aug 12, 2008 at 7:37:07 PM
display order command and reset visibility graphic setting
Tue, Jul 31, 2007 at 2:51:00 PM
Reset Yes/No parameter in schedules to neutral
Wed, Feb 1, 2012 at 3:49:55 PM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Improving Linework in Sections & Elevations
Sun, Mar 30, 2008 at 12:30:48 AM
Page generation time: 0.9767
