Forums >> Revit Building >> Technical Support >> Solid Sweep Creation
Tue, Sep 12, 2006 at 8:23:06 AM | Solid Sweep Creation
razniw
razniw Avatar
4 Stars: 4 Votes
I am trying to create a solid sweep using a kerb profile that follows the gradient of a topography surface. Does anyone know if this is possible to do? I can easily create the sweep horizontally but am unable to make it follow the gradient of the surface!! Any help would be much appreciated, thanks
Tue, Sep 12, 2006 at 5:39:04 PM | RE: Solid Sweep Creation
eldados
eldados Avatar
4.5 Stars: 8 Votes
you won't be able to pick a path using your topo. have a look at my tutorial "complex slabs and pathways" might help... I hope that soon we will have better topo and site tools...
Integrator
KarelCAD
Wed, Sep 13, 2006 at 8:26:12 AM | RE: Solid Sweep Creation
razniw
razniw Avatar
4 Stars: 4 Votes
Thanks for that, your tutorial is very useful indeed. Great lateral thinking, I would never have thought of using the roof command to create a kerb shaped fascia, very clever! Hopefully Autodesk will work something out soon to make this operation much easier. Many thanks Rob
Wed, Sep 13, 2006 at 1:18:28 PM | RE: Solid Sweep Creation
luisrpv
Where can I access these toutorials
Wed, Sep 13, 2006 at 2:13:21 PM | RE: Solid Sweep Creation
coreed
coreed Avatar
4 Stars: 16 Votes
look at the top of the screen under Tutorials HTH Post edited on 2006-09-13 15:27:56
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Solid sweep
Wed, Jun 3, 2009 at 8:22:41 AM
Solid Sweep and doors?
Thu, Apr 27, 2006 at 10:59:11 PM
Cutting Solid Sweep?
Sun, Apr 23, 2006 at 11:03:51 AM
Material surface pattern on a solid sweep?
Wed, Nov 17, 2010 at 2:48:49 PM
Hatch to solid sweep
Fri, Mar 30, 2007 at 2:00:19 AM
Page generation time: 1.2643
